This message is about the Edit Options dialog box that is used for adding, rearranging, and renaming the values that are used in a drop-down list.
1. Terminology. I'd like to recommend that the command button for renaming enumerated values be called Rename. At present, it is called Edit.
2. Copying values. I'd like to recommend that you add a copying feature, so that the enumerated values can be used elsewhere, such as in an email message.
Best wishes,
Paul
