in Search
Error when generating specifications
Last post 06-03-2008, 9:45 AM by crescentmage. 2 replies.
Sort Posts: Previous Next
  •  06-02-2008, 5:39 PM 2904
    I am trying to generate specifications on a shared project, and I am running into a problem.  If I leave the "Include Pages Section" checkbox selected, my spec generates correctly.  If I uncheck the box, my specification only generates the first couple pages (basically pulling in the template) and I get an error: "The generator did not complete sucessfully.  If you would like to report this error click Continue".  If I click Continue, I get a form with the following information "Value of '-2147483648' is not valid for 'Value'. 'Value' should be between 'minimum' and 'maximum'. Parameter name: Value.
    I have uploaded a screenshot of my issue.  I'm not sure if this is a known issue or just specific to me, but I would like to be able to generate specs without the page section.
    Filed under:
  •  06-02-2008, 5:53 PM 2905 in reply to 2904
    Re: Error when generating specifications
    Could you tell us what version of Axure RP you are running (Help->About Axure RP)? Also, if you are using v5, which generator are using (Word 2000 or Word 2007)?
  •  06-03-2008, 9:45 AM 2910 in reply to 2905
    Edit:  After upgrading to .1515, I am no longer getting the error message when I generate the spec, but I am still only getting my template as an output, with no actual information from the Axure project.  This is with the 2007 generator.
    It looks like the error was due to the older version I was running.  Going from .1509 to .1515 seems to have solved the problem.  Thanks!
View as RSS news feed in XML
