in Search
Controlling Z-axis in dynamic panels
Last post 10-05-2008, 4:06 AM by hu_zhenghui. 4 replies.
Sort Posts: Previous Next
  •  09-25-2008, 1:13 PM 3394
    I am mocking up a flash application where we have a grid of buttons. As the user selects a button, it expands to allow text entry and covers up appx. 90% of the other buttons in the grid. I've got the animation to look good, and I'd like to demo two buttons to the client, but right now, I can only have one of the dynamic panels on top.
    Is there a way to change the Z-order of the panels via the cases, so that when one is clicked, that panel is the top layer and will "float" above the other buttons?
  •  09-25-2008, 2:57 PM 3397 in reply to 3394
    Re: Controlling Z-axis in dynamic panels
    Unfortunately, there isn't a way to bring a dynamic panel to the front dynamically right now. A "bring to front" interaction is expected to be added in an update early next year.
  •  10-03-2008, 6:03 AM 3442 in reply to 3394
    rem:
    The "Bring to Front" interaction have not been implemented in Axure RP Pro 5, but the similar effect can be implemented by jQuery, See code below:
    var customization_found = true;
    $(function () {
            var currentPageName;
            window.setInterval(function () {
                    if (currentPageName !== mainFrame.PageName) {
                            switch (mainFrame.PageName) {
                                    case 'Home':
                                            $(mainFrame.document).find('[@title="theButton"]').click(function () {
                                                    $(mainFrame.document).find('[@title="theImage"]').prev().css('z-index', '1');
                                            break;
                            currentPageName = mainFrame.PageName;
            }, 100);
    Skype : huzhenghui
    Gtalk : huzhengh
    Gmail : huzhengh@gmail.com
  •  10-03-2008, 8:18 AM 3443 in reply to 3442
    This doesn't really make things clear huzhenghui...
    At least not for me...
    • Where do I put this code?
    • What do I have to edit?
    • How do I call this script?
    • Does it get overwritten when I generate the prototype?
    Please put a little explanation with your code.
    Thanks in advanced,
    Koen
  •  10-05-2008, 4:06 AM 3447 in reply to 3443
    Koen:
    Thanks in advanced,
    Koen
    Please have a look at http://axure.com/cs/forums/thread/3331.aspx
    Skype : huzhenghui
    Gtalk : huzhengh
View as RSS news feed in XML
