in Search
value of textfield displayed in textpanel via variable
Last post 10-10-2008, 2:30 PM by tisha. 2 replies.
Sort Posts: Previous Next
  •  10-10-2008, 1:53 PM 3460
    Hi I am trying to capture text in a text field on one page, store that value in a variable, then display the text stored in the variable in a text panel on another page.
    I am unable to do this for a text panel as axure does not make variable values available for text panels....
    does anyone know a work around for this? or am i missing something...
    I do not want to display the value in another text field, it needs to just look like text (it's dynamic text really)
  •  10-10-2008, 2:18 PM 3461 in reply to 3460
    Re: value of textfield displayed in textpanel via variable
    Hi tisha,
    In the OnPageLoad of the second page, you can use the action to Set Variable and Widget value equal to Value. Select "text on widget" in the dialog and choose the text panel. Then, click "Edit text..." to specify the value. In that dialog, there is a button in the toolbar "Insert Variable" that you can use to insert variable values. You can also type [[variablename]] to insert a variable in the text.
  •  10-10-2008, 2:30 PM 3463 in reply to 3461
    Excellent! That worked beautifully!
    (don't know how I missed that)
     thank you so much
View as RSS news feed in XML
