in Search
Interactions on page load
Last post 10-21-2008, 9:37 PM by pixeler. 6 replies.
Sort Posts: Previous Next
  •  10-11-2008, 12:38 AM 3464
    Quick question...  Is there a way to get interactions to occur on page load?
  •  10-12-2008, 4:52 AM 3468 in reply to 3464
    Re: Interactions on page load
    pixeler:
    Have you tried the OnPageLoad event of that page?
    Skype : huzhenghui
    Gtalk : huzhengh
    Gmail : huzhengh@gmail.com
  •  10-13-2008, 3:10 AM 3473 in reply to 3464
    Here is an article and video on the OnPageLoad event that might help: http://www.axure.com/p202_6.aspx
  •  10-13-2008, 4:58 PM 3477 in reply to 3473
    Ahhh, I didn't even notice the page interactions section!  I kept reading about OnPageLoad in the forums but couldn't figure out why it wasn't appearing in the Annotations & Interactions winodw.  Thanks guys.
    Note: Although it's labeled correctly, I wonder if this should really be in its own section...  when I think of interactions, I don't necessarily separate page from object.
  •  10-13-2008, 5:02 PM 3478 in reply to 3477
    So here's what I'm trying to do...  There are two links on Page 1:  Both open Page 2, but the second link opens reveals a dynamic panel.
    The tutorial showed how to do this by passing variables within a radio option form, but how about just links?'
    Edit: Ok, I think I got it.  I gave the second link on Page 1 a variable (x) and to open Page 2.  On Page 2, I put in the condition (if variable = x) which would open the dynamic layer.  Thanks.
  •  10-14-2008, 12:03 PM 3487 in reply to 3477
    pixeler:
    In my opinion, the panels are organized by object, the "Page Notes & Page Interactions" panel used for "page" object. and the "Annotations & Interactions" panel used for "widget" object. I think that you prefer that panels are organized by type of member. For example, A "Page Notes & Widget Annotations" panel used for property of "page" or "widget", A "Page Interactions & Widget Interactions" panel used for behavior of "page" or "widget".
    Skype : huzhenghui
    Gtalk : huzhengh
  •  10-21-2008, 9:37 PM 3519 in reply to 3487
    Yeah, I was thinking something more along the lines of this...  FYI, I use 2 monitors so my "palettes" sit on the 2nd screen.  This is probably why I kinda forgot about Page Notes since the frequently used palettes (Widgets and Annotations & Interactions) sit right next to the work area.
    BTW, a couple things regarding the disattached palettes...  First, when Alt-tabbing they show up as separate items in the applications selection box--pretty annoying to suddenly discover that you now have to tab through at least 5 more items to switch to your desired application.  Second, the Page Notes palette retains the "bottom of the page" shape, but should probably look like the others when not attached--it could toggle back and forth.
View as RSS news feed in XML
