in Search
Hide Dynamic Panels while working
Last post 10-15-2008, 3:12 AM by jeppe565. 2 replies.
Sort Posts: Previous Next
  •  10-13-2008, 5:25 PM 3479
    I searched and could not find anything about this. Is there a way to hide a dynamic panel while you are working? I have a large panel as part of a master and it is visually disturbing. On top of that it has to be the top most layer on the page to work so I keep having to move it from the front to the back as I add new objects. It wouldn't matter to me so much but there are six of us working from one project file.
    Thanks in advance!
  •  10-13-2008, 6:28 PM 3482 in reply to 3479
    Re: Hide Dynamic Panels while working
    Hi, there isn't a way to do this in the current version. We are going to be adding a dynamic panel manager in a release planned for early next year so that dynamic panels can be hidden while working on the page.
  •  10-15-2008, 3:12 AM 3493 in reply to 3479
    I've had the same problems. One way to work around this problem is to make the dynamic panel a bit bigger (so it overlaps the other grid) - then choose "send to back". It will then be placed behind the other grid and elements - but will still be visible because you made it slightly bigger. In that way you can always access it and choose "Bring to front"
    I hope this made it clear. It's not the perfect solution, but an acceptable workaround...
View as RSS news feed in XML
