I've about finished my wireframes and I'm starting to delve into the specifications document. I've compiled a list of questions/comments as I work with this aspect of Axure and I'm hoping I can get some feedback on these. Thanks so much for your help (esp. victor!)
1) Whenever I generate a spec the window focus always returns to Axure instead of the spec (happens with the proto, too). I feel this should go ahead and focus on the application (Microsoft Word) where this is being generated to.
2) Is there a better way to do this? I've broken up the site hierarchy to 5 pages with separate parts of the page listed underneath. For example, here's what it looks like in the Site Map palette:
Homepage
Promo tiles
Section 2
Section 3
Product Page
Add to Cart widget
Section 2
Section 3
My reasoning for this is that when I annotate everything on one page, the generated annotations are all grouped under one section and becomes flat. What I'd rather have is a hierarchy where I can place page elements into their own sections.
3) Is there an option to remove the page break between sections? This contributes to a very long document.
4) Is there an option to shrink down images so the section header and image which it refers to fits on one page? I end up with pages where the section header is on one page and the wireframe is on another.
5) I've defined some links to go to URLs. This makes the Interactions column take up a lot of horizontal space and forces the Specifcation column to be shrinked down to about 9 characters. This obviously leads to very tall rows. Is there some way around this?
6) How do I keep the footnotes on my wires from getting cut off? This occurs on the top and left borders. I've figured out how to avoid this on pages by using a border with my wires, but this seems impossible to avoid with dynamic panels.
7) Footnote sizes on different wires seem to differ even though I've checked the option "Do not to scale footnotes with screenshot".
8) I notice that as I define and create the interactions that a lot of extraneous information (due to "tricks" in the prototyping process) is generated to the spec. Do most Axure users just create an identical page to keep the spec and prototyping separate? What's the best way to handle this? (For example, if I create the dropdown menu as shown in http://axure.com/cs/blogs/axure/archive/2006/10/25/Creating-MouseOver-Flyout-Menus-using-Dynamic-Panels.aspx, the image map used behind the menu shows up in the spec. Even if I manually delete the annotation, the footnote on the wireframe is still there. Also, the annotation numbering doesn't renumber.)
9) Is there a way to define cell widths to be consistent for each table generated?
10) It'd be nice to have a cover page (with company, project name, document name, author, created/modified date, version, etc.) and version changes page available.
11) It'd be nice to be able to add padding around wires.
12) This might be more of a Microsoft Word question, but where do I find the Axure-specific styles in the Word template? I'd like to change the header styles but I can't find AxureHeading1, AxureHeading2, etc.
13) It'd be nice to generate to PDF.
14) Table of Contents... wow, 5 pages for the TOC alone. Is there some way to cut this down so only the major sections are displayed?
Thanks again.
