in Search
Drop down lists showing on top of dynamic panel
Last post 12-08-2008, 7:15 PM by victor. 4 replies.
Sort Posts: Previous Next
  •  12-04-2008, 1:41 PM 3811
    This has happened a couple of times now where I am putting a dynamic panel on top of some controls (text inputs, drop down, labels, etc.)
    I've set the order so that the dynamic panel is on top of everything. The dynamic panel also has a white background so you can't see what's behind it.
    When I generate the prototype, everything behind the panel is hidden, except for the drop-down list. It appears on top of the dynamic panel, even though I've changed the order to put that control to the back and bring the dynamic panel to the front.
    Is this a bug or am I missing something? Seems to only happen for drop down controls.
    Thanks,
    Ryan
  •  12-04-2008, 8:48 PM 3813 in reply to 3811
    Re: Drop down lists showing on top of dynamic panel
    Droplist lists and list boxes will always show through in IE6. This should work properly in Firefox and IE7 I believe.
    A workaround for IE6 is to put the droplist into a dynamic panel and hide that panel when the one above it is shown.
  •  12-08-2008, 11:49 AM 3819 in reply to 3813
    Your website says it's compatible only with IE6. If I install IE7 will my prototype still work properly?
    Thanks,
    Ryan
  •  12-08-2008, 7:07 PM 3821 in reply to 3819
    Nobody should be using IE6 anymore, arggggh. It is such an evil thing to have to accommodate.
    Mark Johnston
  •  12-08-2008, 7:15 PM 3822 in reply to 3819
    Yes, the prototypes will work in IE6 and above.
View as RSS news feed in XML
